4506 SupIV confreg=0x2142 does not work
swharvey
Level 3
Level 3
In trying to recover the password on a 4506 w/SupIV running 12.2 IOS, I break the autoboot sequence, and at the rommon type 'confreg 0x2142' but I get a usage:confreg error. I then try 'confreg=0x2142' which it accepts, then a 'reset' but the sytem reloads with a 0x2102 config so the orig config loads. Any ideas?? See set command below:
rommon 4 >set
PS1=rommon ! >
ConfigReg=0x0102
RommonVer=12.2(20r)EW1
BootedFileName=bootflash:cat4500-entservicesk9-mz.122-31.SG.bin
BSI=0
RET_2_RCALTS=
confreg=0x2142
ConsecPostPassedCnt=3
When you are in the rommon mode just type confreg and respond to the prompts as explained in the following link.
http://www.cisco.com/en/US/products/hw/switches/ps663/products_password_recovery09186a00800945f7.shtml
Once you do that the switch should boot without the config and from there proceed with the other usual pw recovery procedures.
Hope that helps!
Sundar
7 Replies 7
swharvey
Level 3
Level 3
Solved it....the autoboot apparently overrides any confreg settings defined by the user, so you have to type 'confreg ' and configure settings for the autoboot.
Hope that helps!
Sundar
Yeah that's what I stumbled onto just before your response, but thanks Sundar very much!
Once you get to this point (below)
do you wish to save this configuration? y/n  [n]:  y
 You must reset or power cycle for new configuration to take effect
There is no need for use confreg 0x2142 any more. Simply reset the switch.
Please - help
Register not change ....
Console  text:
rommon 7 >set
PS1=rommon ! >
RommonVer=15.0(1r)SG11
SupportedFeatures=1
Fa1Enable=1
DiagMonitorAction=Normal
DebugCallHome=00000
BOOT=bootflash:cat4500e-universal.SPA.03.06.04.E.152-2.E4.bin,1;
RET_2_RTS=21:59:46 MSK Mon May 23 2016
BootedFileName=bootflash:cat4500e-universal.SPA.03.06.04.E.152-2.E4.bin
RET_2_RCALTS=
ConsecPostPassedCnt=20
ConfigReg=0x0102
rommon 8 >confreg 0x2142
usage: confreg
rommon 9 >confreg
Configuration Summary :
=> console baud: 9600
=> autoboot from: commands specified in 'BOOT' environment variable
do you wish to change the configuration? y/n [n]: y
enable "diagnostic mode"? y/n [n]: n
enable "use net in IP bcast address"? y/n [n]: n
enable "load rom after netboot fails"? y/n [n]: n
enable "use all zero broadcast"? y/n [n]: n
enable "break/abort has effect"? y/n [n]: n
enable "ignore system config info"? y/n [n]: y
change console baud rate? y/n [n]: n
change the boot characteristics? y/n [n]: n
=> ignore system config info
rommon 10 >set
PS1=rommon ! >
SupportedFeatures=1
Fa1Enable=1
DebugCallHome=00000
RET_2_RCALTS=
ConfigReg=0x0142
rommon 11 >confreg 0x2000
usage: confreg
rommon 12 >confreg
disable "ignore system config info"? y/n [n]: y
rommon 13 >set
PS1=rommon ! >
SupportedFeatures=1
Fa1Enable=1
DebugCallHome=00000
RET_2_RCALTS=
ConfigReg=0x0102
rommon 14 >confreg 0x2142
usage: confreg
rommon 15 >set
PS1=rommon ! >
SupportedFeatures=1
Fa1Enable=1
DebugCallHome=00000
RET_2_RCALTS=
ConfigReg=0x0102
rommon 16 >confreg
rommon 17 >set
PS1=rommon ! >
SupportedFeatures=1
Fa1Enable=1
DebugCallHome=00000
RET_2_RCALTS=
ConfigReg=0x0142
rommon 18 >
I can not get the case to change to 0x2142.
or 0102 or 0142
What to do?
Proceed to the next steps according to the procedure:
https://www.cisco.com/c/en/us/support/docs/switches/catalyst-4000-series-switches/21229-pswdrec-cat4000-supiii-21229.html
does not make sense, as
in state
#switch
does not go over - continues to require a password.
Your advice does not work.
The switch does not reset the password and continues to require its entry after RESET
Удалось добиться сброса.
Нужно терпение и пробовать. На третий раз сработало. В несколько видоизмененном виде, но сработало.
 Перевести регистр в полное соответствие не удалось. Сброс произошел и при значении регистра какой был мною указан ранее.
Всем удачи.
