Community Member
4506 Telnet Issues
I am runnning a 4506 with 12.2(20) EWA. I had configured telnet to the switch and then removed telnet by entering the "no login" command on line vty 0 4.
line vty 0 4
no login
This will disable telnet access to the switch but it did not. I have opned a case with Cisco regarding this isue which I think is a bug. They have created the same issue and are trying to confirm that its a bug. I know you removing the vty line will give me same of affect as no login.
I would like to know if anyone experiencing the same issue and what IOS they are using.
Re: 4506 Telnet Issues
Can't really say most network admins need to be able to telnet into the switches to manage them so generally most of us would not shut them down . If you need security you can always add acl's against the vty lines.
Community Member
Yes, I understand that. The reason for the post is to find similiar issues.
This is *NOT* a bug and working as designed. "no login" under VTY lines just allows telnet without prompting for a password. As you can see in the parser, it clearly says its for password checking only
cse-45b(config-line)#no login ?
local Local password checking
tacacs Use tacacs server for password checking
If you want to disable access, try configuring "no transport input" under the VTY lines.
Hall of Fame Super Gold
no transport input is a good way to stop telnet access. I also have found "no exec" on the VTYs to be quite effective.
