4507 Switch's Power Supply
Does the output indicate the "Bad Power Supply" or it is a configuration issue. This is a brand new switch.
Switch#show environment status powersupply
Power Fan Inline
Supply Model No Type Status Sensor Status
PS1 Unknown Type Unknown bad/off bad/off n.a.
PS2 none -- -- -- --
Switch#show module all
Chassis Type : WS-C4507R
Power consumed by backplane : 40 Watts
Mod Ports Card Type Model Serial No.
1 2 1000BaseX (GBIC) Supervisor(active) WS-X4013+ JAE0926FCYS
3 0 Not enough power for module WS-X4548-GB-RJ45V JAE0922E1T9
4 0 Not enough power for module WS-X4548-GB-RJ45V JAE0922E22N
5 0 Not enough power for module WS-X4424-GB-RJ45 JAE0917AGXF
M MAC addresses Hw Fw Sw Status
1 0014.a8d6.a200 to 0014.a8d6.a201 3.3 12.2(20r)EW1 12.2(18)EW3 Ok
3 0014.69ae.96e0 to 0014.69ae.970f 2.2 Pwr Deny
4 0014.69ae.9770 to 0014.69ae.979f 2.2 Pwr Deny
5 0012.7fc6.3478 to 0012.7fc6.348f 1.7 Pwr Deny
Switch#show power
Power Fan Inline
Power supplies needed by system : 1
Power supplies currently available : 0
*** Insufficient power supplies present for specified configuration ***
Power Summary Maximum
(in Watts) Used Available
System Power (12V) 250 0
Inline Power (-50V) 0 0
Backplane Power (3.3V) 40 0
Total Used 290 (not to exceed Total Maximum Available = 0)
*** Insufficient power available for current chassis configuration! ***
Switch#show ver
IOS (tm) Catalyst 4000 L3 Switch Software (cat4000-I9S-M), Version 12.2(18)EW3, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2005 by cisco Systems, Inc.
Compiled Mon 07-Feb-05 19:21 by hqluong
Image text-base: 0x00000000, data-base: 0x010BFA78
ROM: 12.2(20r)EW1
Dagobah Revision 95, Swamp Revision 3
Switch uptime is 2 minutes
System returned to ROM by reload
System image file is "bootflash:"
cisco WS-C4507R (MPC8245) processor (revision 4) with 262144K bytes of memory.
Processor board ID FOX092206E6
Last reset from Reload
1 Virtual Ethernet/IEEE 802.3 interface(s)
2 Gigabit Ethernet/IEEE 802.3 interface(s)
511K bytes of non-volatile configuration memory.
Configuration register is 0x2101
Switch#
1 REPLY
Re: 4507 Switch's Power Supply
What p/sis it ? have you tried switching power supply to another slot ? Do you have the part number for the p/s
454
