Webcast-Catalyst9k
4507R catalyst switch port connect/disconnect
hi,
I have a big problem with a 4507R catalyst switch(The all port are 1Gb).
When I configure a port to 1G, this port connect, disconnect,connect, disconnect ...
But when i configure this port to 100M it's ok.
The pb is that the all port are busy, i don't have a free port to pluged the cable.
I can't restart the catalyst.
Please help me!! because it's very urgently!!
It exist a solution without restart....
In advance thank you
Re: 4507R catalyst switch port connect/disconnect
I have always the same pb.
Please help me!!
Purple
Sure you have a cat 6 8 wire patch cable . Gig takes all 4 pairs of wires to run correctly . I also have always left the port as auto to runn gig . Also if you hardcode the switch you have hardcode your nic too .
Yes, the cable is ok.
I have tested with an other cable and i have the same pb.
Please help me
set speed/duplex to AUTO on 4507 port and server NIC.
Then shut the interface and then no shut.
see if it helps ...
164
