Webcast-Catalyst9k
500 Express Switch issues with voice vlans
Trying to configure a port on a 500 Express switch to be in access mode in the voice vlan so that a separate router can be connected to this. The gui won't let me assign the voice vlan in access mode ?!?! I have to be missing something here . . .
To see what I'm trying to accomplish, here is the config I would use on a 3560:
vlan 2
name data
vlan 3
name voice
int fa0/1
description to voice router (2811)
switchport mode access
switchport access vlan 3
int fa0/2
description to data router (1700)
switchport access vlan 2
int range fa0/3 - 24
switchport trunk native vlan 2
switchport mode trunk
switchport voice vlan 3
mls qos trust device cisco-phone
spanning-tree portfast
No problem configuring the port to the data side router. No problem configuring the ports to trunk for data/voice vlan for PCs connected through cisco phones.
Only problem is getting the port that connects (in access mode) to the voice router to be in the voice vlan.
1 REPLY
Re: 500 Express Switch issues with voice vlans
Figured it out - upgraded to 12.2(25)SEG
Once I did that, I was able to select a port role of "Server" and then by clicking "Customize" I was able to select access vlan "Cisco-Voice" and Server Type "Trusted" even though it's going to a router. Heh. Gotta love the gui.
106
