Community Member
5500 logging severity "32" for default and current after upgrade.
Hey all,
I was wondering if someone could shed some light on this one for me.
After upgrading 5500s to 6.2(2) not to long ago, I noticed that some of our 5500s changed the reported severity level in sh logging, and started reporting all logging as if it were in debug mode. However, the "server severity:" setting reported that "warning(4)" was set. If you looked at the logging buffer, debug messages were being reported (severity level 7 and below messages).
[I've included a cut and paste of the output below from a sho logging]
All 5500s were at the same CatOS code before the upgrade, and all were upgraded to the same code from the same image on the same TFTP server... Any ideas why this happened?
Also, the resolve appears to just set the logging level default back to 4 with the
'set logging level all 4 default'
Atleast, that has worked so far.
Thanks for any thoughts in advance, I've included the output below...
<snip output of sho logging>
Logging buffer size: 500
timestamp option: enabled
Logging history size: 1
Logging console: disabled
Logging telnet: disabled
Logging server: enabled
server facility: LOCAL7
server severity: warnings(4)
Current Logging Session: disabled
Facility Default Severity Current Session Severity
cdp 32 32
cops 32 32
drip 32 32
dtp 32 32
earl 32 32
fddi 32 32
filesys 32 32
Re: 5500 logging severity "32" for default and current after upg
Definetly smells like a bug, but I could not find any. What version did you upgrade from. I'll see if it's reproducible
