60 Pin Serial to 60 Pin Serial Crossover Cable
if I connect two routers via serial interfaces with a 60 Pin Male DTE - 60 Pin Male DCE crossover cable, will I be able to put an IP address on each side and route across the connection?
John.
1 REPLY
Re: 60 Pin Serial to 60 Pin Serial Crossover Cable
Yes. make sure to configure a clock rate on the DEC side.
228
