Webcast-Catalyst9k
6260 DSLAM problem
My customer is performing the following testing scenerio:
827 CPE --- 6260 DSLAM ----------- Cisco 3660
ATM
The 6260 got 2 problems at the moment.
1. An error message 'NI2 module loss of active clock sync'
2. the interface ATM1/1 connected to 827 trains itself repeatedly
The 827 is directly connected to 6260 using RJ11 connectors
and then to 3660 using a fibre.
Does anyone have idea how to solve these problems?
Here are the config
6260:
boot system flash:ni2-dsl-mz.20-8.DA4
slot 1 atuc-1-4dmt
dsl-profile default
network-clock-select 1 ATM0/1
ip subnet-zero
atm address 47.0091.8100.0000.0003.fe57.5401.0003.fe57.5401.00
atm router pnni
no aesa embedded-number left-justified
node 1 level 56 lowest
redistribute atm-static
interface ATM0/0
no ip address
no ip directed-broadcast
no ip mroute-cache
atm cac service-category abr deny
atm maxvp-number 0
interface Ethernet0/0
no ip address
no ip mroute-cache
shutdown
interface ATM0/1
no ip address
no ip mroute-cache
atm ilmi-keepalive
interface ATM1/1
no ip address
no atm ilmi-keepalive
atm pvc 4 100 interface ATM0/1 4 100
1 REPLY
Re: 6260 DSLAM problem
My previous post seems missing the lower part.
Here it is.
3660:
interface ATM1/0
ip address 172.17.3.36 255.255.255.0
no atm scrambling cell-payload
pvc 4/100
protocol ip 172.17.3.35 broadcast
encapsulation aal5snap
By the way, I got several questions.
1. Does the above implementation support PPPoA and PPPoE?
2. Is the any sample config that corresponds to such implementation.
I can only find config about 6130 and 6400.
Thanks.
Daniel
105
