12-05-2005 06:23 AM - edited 03-03-2019 01:01 AM
We have 2 3750 stacks connected to 2 6500 switches.
One stach is connected to a 6513 switch and has no problems.
The other stach is connected to a 6506 switch and on the truk ports we get a lot of rxoversizedpkts on the 6506.
We don't use jumbosize and MTU size is equal.
What is it we doing wrong?
Solved! Go to Solution.
12-05-2005 12:46 PM
what type of module on the 6506 is reporting this, and what version of code?
If this is a 67XX module, you may be running into CSCef87392
12-05-2005 12:46 PM
12-05-2005 10:20 PM
Oh oh, it's a WS-X6748-GE-TX
but on the 6513 we connected to the same module.
12-05-2005 10:26 PM
What is the "CSCef87392" ?
I can't find it.
12-05-2005 10:56 PM
What version of code u r running :
Here is the exp:
Release Notes
A Catalyst 6500 may increment giants on 67xx cards for ports that are trunking.
This does not affect the performance of the switch, and is purely cosmetic.
Fixed in Version: 8.6(0.21)TAL, 8.4(0.61)RCC03, 8.5(0.5)JAC, 12.2(17d)SXB11
Found in 12.2(18)SXD
HTH,
-amit singh
12-05-2005 11:10 PM
Ok i found it,
Thanks for youre help!!
