6500 Backplane Traffic?
We are running a 6513, Sup2's, hybrid, ver 8.3.7 as a collapsed backbone with many gig fiber links providing connectivity to directly attached servers in a single data center.
We plan to transition the servers to access layer 6500's connected by multiple 10G links.
How can I determine the actual traffic across the backplane of the existing 6513?
Tom
Re: 6500 Backplane Traffic?
You can use the command "sh system" to check for backplane traffic if running hybrid OS.
Or you could use MRTG/RRDtool to gather longterm stats.
what other methods are there to check backplane utilization on the 6513? I am not running hybrid OS and I want to be able to see a trend of it. Also, I do not have MRTG/RRDtool.
Silver
With a Network Analysis Module!
See pic.
As you can see this report is from a very idle switch.
Please rate this post.
Brad
sho system
Modem Baud Backplane-Traffic Peak Peak-Time
disable 9600 0% 20% Sat Dec 31 2005, 07:24:04
So, what does this mean?
Tom
Purple
It means basically as of your snapshot time that your backplane usuage is less than 1 % , you had a peak of 20% on 12/31/05 at 7:24 AM .
161
