6500 CatOs L3 ethernet port
Hi all,
I know how to configure L3 uplink to router from 6500 ios switch.
interface g0/1
no switchport
ip address x.x.x.x x.x.x.x
same thing how will i do it on 6500 CATOS with msfc?
Rajesh
Purple
Re: 6500 CatOs L3 ethernet port
msfc
conf t
inter vlan XX
ip address xxx.xxx.xxx.xxx
on the layer 2 supervisor
set vlan XX slot/port
Thanx glen...I am wondering if we configure multiple ports on that vlan in sup what will happen?
how msfc sense that is this port for L3uplink?
Rajesh
Hi Rajesh,
You cannot configure a purely layer 3 port in CatOS as you can in IOS.
The closest method to doing this is what Glen described, which is still a layer 2 port with an associated layer 3 virtual interface on the MSFC.
In IOS, as you know, you can configure a physical port to be a layer 3 interface, but this isn't possible in CatOS.
HTH,
Bobby
*Please rate helpful posts.
Purple
The answer is yes on the supervisor (layer 2 )you can put as many ports into that vlan as you want .
302
