09-20-2002 09:04 AM - edited 03-02-2019 01:31 AM
does anyone know if the fan assembly is hot-swappable for the 6500 series?
09-20-2002 11:23 AM
hi g,
I have pulled the fan assembly out. Although I don't see any specific reference to the fan assembly as a module. It does have the same mounting bolts as all the other hot-swappable module..
I'll leave it up to the librarians pull out the reference material. Did you check the installation guide there may be a reference to it in there.
G
09-22-2002 09:12 AM
It is hot swapable..
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat6000/6000hw/inst_aug/01over.htm#xtocid8
Hope this helps
Erum
09-20-2002 12:17 PM
It is hotswappable. But make sure you dont leave the switch for long without a fan tray
