6500 hot swap modules
does anyone know if the fan assembly is hot-swappable for the 6500 series?
Re: 6500 hot swap modules
hi g,
I have pulled the fan assembly out. Although I don't see any specific reference to the fan assembly as a module. It does have the same mounting bolts as all the other hot-swappable module..
I'll leave it up to the librarians pull out the reference material. Did you check the installation guide there may be a reference to it in there.
G
Bronze
It is hotswappable. But make sure you dont leave the switch for long without a fan tray
295
