Webcast-Catalyst9k
6500 ip flow top-talkers
Hi All,
i would like to enable "ip flow-top-talkers" in 6500 in native mode.
this command is not supported in current version.
is there any alernative command or it won't support.
running ios is s72033-pk9sv-mz.122-18.SXD5.bin
Thanx in advance for the response.
Rajesh
1 REPLY
Anonymous
N/A
Re: 6500 ip flow top-talkers
This command was introduced only from 12.2(25)S and this feature was integrated into 12.3(11)T. So,if you are using any lower version other than this,this command will not work at all.If possible,better download any of the above 2 versions from cisco website and upgrade your IOS.
710
