Community Member
6500 not recognizing Line cards need help
Folks,
I have a 6500 series switch which does not recognize line cards, it has a older version of SUP. do you think it is the old code causing the problem, or hardware related issue. Many thanks in advance.
show ver
WS-C6509 Software, Version NmpSW: 6.3(9)
Copyright (c) 1995-2002 by Cisco Systems
NMP S/W compiled on Sep 23 2002, 17:51:19
System Bootstrap Version: 5.2(1)
Hardware Version: 2.0 Model: WS-C6509 Serial #: SCA043501H3
PS1 Module: WS-CAC-2500W Serial #: ART0429010R
Mod Port Model Serial # Versions
1 2 WS-X6K-SUP1A-2GE SAD03426592 Hw : 1.0
Fw : 5.2(1)
Fw1: 5.1(1)CSX
Sw : 6.3(9)
Sw1: 6.3(9)
WS-F6020A SAD03276676 Hw : 2.0
2 48 WS-X6348-RJ-45 SAD043305B2 Hw : 1.4
Fw : 5.4(2)
Sw : 6.3(9)
3 48 WS-X6348-RJ-45 SAL05041XE5 Hw : 1.4
Fw : 5.4(2)
--More-- Sw : 6.3(9)
4 8 WS-X6608-T1 SAD0441027J Hw : 1.1
Fw : 5.4(2)
Sw : 6.3(9)
HP1: (not online); DSP1: (not online)
HP2: (not online); DSP2: (not online)
Sending RARP request with address 00:d0:02:6c:bf:ff
Sending DHCP packet with address: 00:d0:02:6c:bf:ff
HP3: (not online); DSP3: (not online)
HP4: (not online); DSP4: (not online)
HP5: (not online); DSP5: (not online)
HP6: (not online); DSP6: (not online)
HP7: (not online); DSP7: (not online)
HP8: (not online); DSP8: (not online)
DRAM FLASH NVRAM
Module Total Used Free Total Used Free Total Used Free
1 65408K 40313K 25095K 16384K 9490K 6894K 512K 261K 251K
Uptime is 0 day, 0 hour, 13 minutes
Console> (enable) show test
Diagnostic mode: minimal (mode at next reset: minimal)
Environmental Status (. = Pass, F = Fail, U = Unknown, N = Not Present)
PS1: . PS2: N PS1 Fan: . PS2 Fan: N
Chassis-Ser-EEPROM: . Fan: .
Clock(A/B): A Clock A: . Clock B: .
VTT1: . VTT2: . VTT3: .
Module 1 : 2-port 1000BaseX Supervisor
Network Management Processor (NMP) Status: (. = Pass, F = Fail, U = Unknown)
ROM: . Flash-EEPROM: . Ser-EEPROM: . NVRAM: . EOBC Comm: .
Line Card Status for Module 1 : PASS
Port Status :
Ports 1 2
Line Card Diag Status for Module 1 (. = Pass, F = Fail, N = N/A)
Module 1
--More-- Earl IV Status :
NewLearnTest: .
IndexLearnTest: .
DontForwardTest: .
DontLearnTest: .
ConditionalLearnTest: .
BadBpduTest: .
TrapTest: .
MatchTest: .
Ingress/EgressSpanTest: .
CaptureTest: .
ProtocolMatchTest: .
ChannelTest: .
Loopback Status [Reported by Module 1] :
Ports 1 2
Console> (enable)
Bronze
Re: 6500 not recognizing Line cards need help
Are the modules stuck in an "other" state in the "show module" output because the "show version" looks okay ?
What is the model number of the module the supervisor is not able to recognize ?
Community Member
Thanks for the responce.
The module numbers are:
6608-t1
6348 inline power
Bronze
hi, please elaborate further on what you mean when you say the modules are not recognized. I checked the release notes and 6.3(9) supports both those modules and according to the "show version" you posted, the 6348 and 6608-t1 cards are recognized..
thanks.
Community Member
All cards have amber lights on them. one 1 card the status light is green but the ports are all amber.
Any help would be apprexciated.
Bronze
A module with amber ports normally means 2 things:
a) ports are inactive
b) ports are errdisabled
Issue a "show port" to determine which state the ports are in.
Next, try the following:
a) clear the config on the module using the "clear config " command.
b) Also check the vlans the ports are assigned to. If the vlan doesn't exist in the vlan database ( check the "show vlan" command " ) then create the vlan using the "set vlan " command.
If the steps i've outlined don't work, paste the "show port " output for us to see.
Silver
I have a switch with same issue like yours, Did you find a solution for this. I am using 7.6.5
Purple
You need to set the test diagnostics to complete and reload , this may give you a better explanation of why these cards are not recognized and will recognize a hardware issue if it's a card issue , right now your diags are set as minimal which skips most of the POST tests . Maybe you can post a show mod and or sh ver , sh logg buff 1000 etc...
279
