Webcast-Catalyst9k
6500 sup320 redudancy engine not work
I installed a redudancy sup720 sup-engine on my 6509. But it is not working properly. How can I make the redudancy engine work properly?
At first I configured redudancy mode like this:
redundancy
mode sso
main-cpu
auto-sync bootvar
I place this engine card in redudancy mode but it start to reboot and reboot again and again. I thought this may be due to the different IOS version.
Then I place this engine card in main mode (unplug the main card) and uploaded the same IOS as the primary one , it shows me log as below:
IOS (tm) s72033_rp Software (s72033_rp-PSV-M), Version 12.2(18)SXD6, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2005 by cisco Systems, Inc.
Compiled Wed 17-Aug-05 17:34 by evmiller
BOOT = sup-bootflash:,1
BOOTLDR =
Configuration register = 0x2102
Peer (slot: unavailable) information is not available because it is in 'DISABLED' state
CMC-6509-2#
Self extracting the image... [OK]
System Bootstrap, Version 8.4(2) Release
Copyright (c) 1994-2005 by cisco Systems, Inc.
Cat6k-Sup720/SP processor with 524288 Kbytes of main memory
Autoboot executing command: "boot bootflash:"
Invalid device specified
Booting from default device
Initializing ATA monitor library...
string is bootdisk:s72033-ipservices_wan-mz.122-18.SXF4.bin
this shows at first, the redudancy engine wants to boot from bootflash: .But this sup-engine only have sup-disk. So it reboot angain and again.
Also when I type "boot" in rommon mode after i press ctrl+break the redudancy engine start to boot IOS.
Then I use "sh ver" . It shows my log as below:
6509_B#sh ver
6509_B uptime is 13 minutes
Time since 6509_B switched to active is 12 minutes
System returned to ROM by unknown reload cause - suspect boot_data[BOOT_COUNT] 0x0, BOOT_COUNT 0, BOOTDATA 19 (SP by power-on)
System image file is "sup-bootflash:s72033-psv-mz.122-18.SXD6.bin"
Re: 6500 sup320 redudancy engine not work
Looking the following ouput, I see that the Sup720 is trying to boot an hybrid image. Convert it to Native IOS and issue wr mem from the active Supervisor to syncrhonize boot variables.
can you explain how to "Convert it to Native IOS " ? Do you mean download a new IOS?
But this IOS is the same one in my active Supervisor .And it works in my active Supervisor .
You will need to manually convert it the first time. Schedule a window and follow steps in the following page
http://www.cisco.com/warp/public/473/81.html
You can use a compact flash card and use the Native IOS image on it.
Thanks .
Maybe I miss one point: this redudancy can work in correct login mode after i type in "boot" in rommon. And it load the correct IOS and give me a ios login mode than catos mode.
Afeter i read the document you mentioned I wonder shall I convert it again?
217
