Community Member
6500 Supervisor Engine 2 console issue
use rolled over cable and RJ45-DB9 connect 6500 SUP2 console to PC ( 9600, 8bit, no parity, 1 stop and flow control none ), with console mode 1 on SUP2 console. I can see the message from system ( when reload and insert the GBIC ), but can't input command ( no response when hit "enter" )
Re: 6500 Supervisor Engine 2 console issue
Do you have the same problem consoling into another device with the same setup (PC, terminal config, console cable)?
-Bobby
Community Member
no, use the same setup, my pc can access other cisco box ( 12410, 7609 SUP720 ).
The weird thing is I can see the system output ( such as GBIC insert, PCMCIA card insert ),looks like system no response to the input.
Purple
I think we saw something like this once , ended up having to RMA the supervisor.
195
