04-06-2006 03:59 AM - edited 03-03-2019 02:41 AM
Guys,
Very quick one, does anyone have any stats on throughputs on a VLAN Interface on a 6500 MSFC2
I just remember the old days where if you had an RSM, and it had a VLAN interface, the throughtput was 400Mbps (or sommat like that)
Can a 6500 MSFC2 SVI run at a full gig?
Sorry if this sounds a little crazy.
Kindest regards,
Ken
04-06-2006 04:14 AM
Hi Ken,
AFAIK the throughput is 1Gbps. Yes it runs at 1gig.
Check the output from one router
sh int vlan102
Vlan102 is up, line protocol is up
Hardware is EtherSVI, address is xxxx.xxxx.xxxx (bia xxxx.xxxx.xxxx)
Description: *** Data vlan to user switch***
Internet address is x.x.x.x
MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
Check the BW entry.
HTH, if yes please rate the post
Ankur
04-06-2006 05:12 AM
Hi Ankur, Many thanks for your input.
I dont think i worded my question correctly atall. Sorry!
What I was getting at - and this was some time ago.
You used to have a cat5500 and you created the SVIs on there. The trunk between the switch and RSM (i think as far as I can remember) had a throughput rating of 400Mbit, so if you had x ammount of SVIs, you could oversubscribe the trunk between the switch and RSM.
Does the 6500 switch archtecture have the same thing?
So, as you state, YES, the SVI runs a 1G, if you had 25 1G SVIs, and they were all running at 70%, could you oversubscibe the link from the MSFC to the switching engine (SUP)
Its just so I know how to size a 6500 ?
I hope that makes sense, and again, thx for the input thus far.
Kindest regards,
Ken
04-06-2006 05:30 AM
You also have to remember not a lot a traffic gets passed up to the layer 3 (msfc) end because most of it is switched in hardware using CEF .Even on the old 5500's most traffic never hit the RSM , the first packet got sent to the RSM and all susequent packets in the flow were hardware switched using mls thus you you could have dozens of SVI"s configured but the RSM cpu would run maybe 10% . Thats what multi layer switching is about . With the advent of items like DFC cards even less is punted up to the msfc , it is routed right down on the line cards themselves so how big that that pipe is less important than you might think. If you have an SVI running at 70% you have a major problem and you would need to track down what the problem was because very little traffic should be routed to the SVI in normal circumstances.
04-06-2006 06:00 AM
That makes a lot of sense.
I just did some research, and yes it was 400M on a 5500 and now 1000 for the 6500 with an MSFC 2, so yes, they have not increased it that much becuase As you say, it should all be cef-based MLS or traditional MLS based
Many thx all,
Ken
on a 6500 switch
Switch sh port 15/1
* = Configured MAC Address
Port Name Status Vlan Duplex Speed Type
15/1 MSFC connected trunk full 1000 Route Switch
Port Trap IfIndex
15/1 disabled 5
Port Status ErrDisable Reason Port ErrDisableTimeout Action on Timeout
15/1 connected - Enable No Change
Port Align-Err FCS-Err Xmit-Err Rcv-Err UnderSize
15/1 0 0 0 0 0
Port Single-Col Multi-Coll Late-Coll Excess-Col Carri-Sen Runts Giants
15/1 0 0 0 0 0 0 -
Port Last-Time-Cleared
15/1 Sat Jul 23 2005, 20:11:34
Idle Detection
on a 5505 switch
Console> show port status
A response, similar to the following, is displayed:
Port Name Status Vlan Level Duplex Speed Type
1/1 connected 523 normal half 100 100BaseTX
1/2 notconnect 1 normal half 100 100BaseTX
2/1 connected trunk normal half 400 Route Switch
3/1 notconnect trunk normal full 155 OC3 MMF ATM
5/1 notconnect 1 normal half 100 FDDI
5/2 notconnect 1 normal half 100 FDDI
