12-20-2005 07:51 AM - edited 03-03-2019 01:11 AM
Can anybody tell me which Bytes from the L2 Header are included in the policing calculation if i police the rate of a ethernet interface (with a policy-map)? i.e. Preamble, dot1q, mac......
Thanks for any feedback!
12-21-2005 06:41 AM
Hi there,
funny enough the info is found where one wouldn´t really expect it:
What Bytes Are Counted by IP to ATM CoS Queueing?
http://www.cisco.com/en/US/tech/tk39/tk824/technologies_tech_note09186a00800942f5.shtml
So the answer would be: no preamble and no CRC is counted. It is the same byte counter implemented as with show interface.
Hope this helps
Martin
12-22-2005 04:44 AM
Hallo Martin
Tanks for your feedback! Today i measured that the vlan tag is alo excluded int the policing calculation. The calculation is based on IP-Packet+18Bytes Ethernet overhead.
Cheers und frohe Festtage :-)
12-22-2005 04:53 AM
Frohe Festtage!
