6506 keep rebooting
every 2 days my router keep rebooting and this is the error i keep getting RxSBIF_SEQ_NUM_ERROR:slot=1, pinnacleMask=0X1, errSeqNum=ff,source Index=0X0, errorType=0X3 is there a fix to this problem
Re: 6506 keep rebooting
Can you paste the output of sh ver and sh log
Network Management Processor (ACTIVE NMP) Log:
Reset count: 39
Re-boot History: Jan 04 2003 03:59:54 0, Jan 03 2003 22:32:05 0
Jan 01 2003 16:30:47 0, Dec 31 2002 11:59:20 0
Dec 31 2002 09:14:43 0, Dec 31 2002 03:21:07 0
Dec 30 2002 13:37:04 0, Dec 30 2002 02:26:25 0
Dec 29 2002 06:49:59 0, Dec 29 2002 06:36:19 0
Bootrom Checksum Failures: 0 UART Failures: 0
Flash Checksum Failures: 0 Flash Program Failures: 0
Power Supply 1 Failures: 1 Power Supply 2 Failures: 2
Swapped to CLKA: 0 Swapped to CLKB: 0
Swapped to Processor 1: 0 Swapped to Processor 2: 0
DRAM Failures: 0
Exceptions: 0
Loaded NMP version: 6.3(5)
Reload same NMP version count: 40
EOBC Exceptions/Hang: 0
Heap Memory Log:
Corrupted Block = none
NVRAM log:
01. 9/24/2002,11:05:38: RxSBIF_SEQ_NUM_ERROR:slot=1, pinnacleMask=0X1, errSeqNum=ff,source Index=0X0, errorType=0X3
02. 12/19/2002,18:41:07: RxSBIF_SEQ_NUM_ERROR:slot=1, pinnacleMask=0X1, errSeqNum=ff,source Index=0X0, errorType=0X3
03. 12/31/2002,03:22:00: RxSBIF_SEQ_NUM_ERROR:slot=1, pinnacleMask=0X1, errSeqNum=ff,source Index=0X0, errorType=0X3
04. 12/31/2002,09:15:36: RxSBIF_SEQ_NUM_ERROR:slot=1, pinnacleMask=0X1, errSeqNum=ff,source Index=0X0, errorType=0X3
05. 1/3/2003,22:32:58: RxSBIF_SEQ_NUM_ERROR:slot=1, pinnacleMask=0X1, errSeqNum=ff,source Index=0X0, errorType=0X3
06. 1/4/2003,04:00:47: RxSBIF_SEQ_NUM_ERROR:slot=1, pinnacleMask=0X1, errSeqNum=ff,source Index=0X0, errorType=0X3
Module 3 Log:
Reset Count: 37
Reset History: Sat Jan 4 2003, 04:00:55
Fri Jan 3 2003, 22:33:06
Wed Jan 1 2003, 16:31:48
Tue Dec 31 2002, 12:00:21
Module 15 Log:
Reset Count: 40
Reset History: Sat Jan 4 2003, 04:01:13
Fri Jan 3 2003, 22:33:24
Wed Jan 1 2003, 16:32:06
Tue Dec 31 2002, 12:00:40
WS-C6506 Software, Version NmpSW: 6.3(5)
Copyright (c) 1995-2002 by Cisco Systems
NMP S/W compiled on Feb 7 2002, 21:52:11
System Bootstrap Version: 7.1(1)
Hardware Version: 3.0 Model: WS-C6506 Serial #: TBM06224721
PS1 Module: WS-CAC-2500W Serial #: ART062200DC
PS2 Module: WS-CAC-2500W Serial #: ART062200EL
Mod Port Model Serial # Versions
1 2 WS-X6K-SUP2-2GE SAL0618057E Hw : 3.7
Fw : 7.1(1)
Fw1: 6.1(3)
Sw : 6.3(5)
Sw1: 6.3(5)
WS-F6K-PFC2 SAL06152FKU Hw : 3.2
3 16 WS-X6516-GBIC SAD045204DF Hw : 4.1
Fw : 6.3(1)
Sw : 6.3(5)
15 1 WS-F6K-MSFC2 SAL06152G2V Hw : 2.3
Fw : 12.1(11b)E
Sw : 12.1(11b)E
DRAM FLASH NVRAM
Module Total Used Free Total Used Free Total Used Free
1 130944K 62144K 68800K 32768K 7321K 25447K 512K 260K 252K
Unfortunately, the switch did not save any stack info to the output of show log for the most recent crash. We had a bug(CSCdw57262) due to which the switch would not save stack of certain crashes to NVRAM. This bug is fixed in 6.3(7) and later but I suggest that you upgrade to 6.3(10). Here is the
release notes
http://cio.cisco.com/univercd/cc/td/doc/product/lan/cat6000/relnotes/78_11235.htm
If you cannot upgrade very soon, I suggest that you let a console session
monitor the switch as the switch would dump stack info to the console as well
194
