09-19-2006 11:43 PM - edited 03-03-2019 05:07 AM
For the moment, we don't want to active routing on this 6506. I enter the command no ip routing + ip default-gateway ... and it works fine
Pb : When i reload the switch, ip routing is active automatiquely !!!
Is this a bug or a bad configuration from my part ?
09-19-2006 11:45 PM
Did you save the configuration?? You need to save your running configuration to your startup configuration! You can do the same by entering either of the following commands:
- copy run start
or
- write
Hope this helps!
AbhisheK
Please rate all helpful posts!!!
09-20-2006 12:08 AM
I save it
09-20-2006 12:49 AM
Hi there,
When you have saved it issue the command "show start" to check the startup config and to make sure that your command is in there.
If for some reason it isn't working, then you can always take the ip addresses off the vlans except for the management one. Then it'll have nothing to route with!!
Hope that helps
LH
Please rate all posts
09-20-2006 01:35 AM
when i save it, no ip routing command is neither in startup and running.
