6509 and 5000 problems trunking to a 1924
Can anyone help? I am having a problem getting my 1924's to connect in trunk mode to the 6509 and 5000. Some of the 1924's are fine, but others keep losing the connection. I know not all switches support DTP frames so I set both ends of the trunk to nonegotiate. The connect will come up but after awhile it gets lost, but the 6509 and 5000 still say it is connected. Any ideas?
  • Other Network Infrastructure Subjects
Re: 6509 and 5000 problems trunking to a 1924
6509 catOS (5000 is)? Errors on the ports? Native vlans the same? Can you post the configs of an example of two ports (one at each end)? Any errors reported?
Steve
The 5000 number is a 5000 Series switch, I have the 1924's hooked to both to 5000 series and 6509 series switches. They are both in the same native vlan, config was both set to trunk, nonegotiate for vlans 1-1005, isl. No errors on either sides.
Catalyst 1900 - Port A Statistics Report
Receive Statistics Transmit Statistics
Total good frames 41380201 Total frames 5591810
Total octets >2865721182 Total octets 1131046715
Broadcast/multicast frames 35748341 Broadcast/multicast frames 496019
Broadcast/multicast octets 3953863994 Broadcast/multicast octets 59179197
Good frames forwarded 41376941 Deferrals 0
Frames filtered 3260 Single collisions 0
Runt frames 0 Multiple collisions 0
No buffer discards 0 Excessive collisions 0
Queue full discards 0
Errors: Errors:
FCS errors 0 Late collisions 0
Alignment errors 0 Excessive deferrals 0
Giant frames 0 Jabber errors 0
Address violations 0 Other transmit errors 0
This is the 6509 stats
Port Name Status Vlan Duplex Speed Type
3/18 connected 1 full 100 100BaseFX MM
Port Security Violation Shutdown-Time Age-Time Max-Addr Trap IfIndex
3/18 disabled shutdown 0 0 1 disabled 36
Port Num-Addr Secure-Src-Addr Age-Left Last-Src-Addr Shutdown/Time-Left
3/18 0 - - - - -
Port Broadcast-Limit Broadcast-Drop
3/18 5.00 % 0
Port Send FlowControl Receive FlowControl RxPause TxPause Unsupported
admin oper admin oper opcodes
3/18 off off off off 0 0 0
Port Status Channel Admin Ch
Mode Group Id
3/18 connected auto silent 146 0
Port Align-Err FCS-Err Xmit-Err Rcv-Err UnderSize
3/18 0 0 0 0 0
Port Single-Col Multi-Coll Late-Coll Excess-Col Carri-Sen Runts Giants
3/18 0 0 0 0 0 0 0
87
