Community Member
6509 Catos 6.3(7) %SYS-3-SYS_LCPERR3:Module [dec]: Coil Pb Rx Underflow Err
We are currently in the process of installing approx 25 new C6509 with the following module layout & versions:
1 1 2 1000BaseX Supervisor WS-X6K-SUP1A-2GE yes ok
2 2 2 1000BaseX Supervisor WS-X6K-SUP1A-2GE yes standby
3 3 48 10/100BaseTX Ethernet WS-X6348-RJ-45 yes ok
5 5 48 10/100BaseTX Ethernet WS-X6348-RJ-45 yes ok
7 7 48 10/100BaseTX Ethernet WS-X6348-RJ-45 yes ok
8 8 48 10/100BaseTX Ethernet WS-X6348-RJ-45 yes ok
9 9 48 10/100BaseTX Ethernet WS-X6348-RJ-45 yes ok
WS-X6K-SUP1A-2GE SAL0607J6HG Hw : 7.1
Fw : 5.3(1)
Fw1: 5.4(2)
Sw : 6.3(7)
Sw1: 6.3(7)
WS-F6K-PFC SAL0603GU2J Hw : 2.0
WS-X6348-RJ-45 SAL06334L43 Hw : 6.1
Fw : 5.4(2)
Sw : 6.3(7)
WS-F6K-VPWR Hw : 1.0
We have been experiencing the below line card errors which has occasionally affected single ports or sometimes all ports on a WS-X6348-RJ-45.
2002 Oct 28 14:58:57 GMT +00:00 %SYS-3-SYS_LCPERR3:Module 3:Coil Pb Rx Underflow Error - Port #20:
2002 Oct 28 14:58:57 GMT +00:00 %SYS-0-SYS_LCPERR0:Module 3: Coil Pb Rx Parity Error - Port #20:
This has now occured on approximately 5 out of 25 of the newly installed modules. At first I have been putting this down to a faulty ASIC and replacing the cards. I am consolidating the serial numbers in case of a faulty batch. The DOA rate seems suspicously high!
Has anybody experienced this problem whilst running Catos 6.3(7)? Did a software upgrade fix the problem.
Cheers, John.
Silver
Re: 6509 Catos 6.3(7) %SYS-3-SYS_LCPERR3:Module [dec]: Coil Pb R
John
I have encountered this several times . It was identified as a bug CSCdu03935 .
It could either hardware or a software. Take a look at the following page on CCO
http://www.cisco.com/warp/public/473/119.html#coil9
504
