6509 Console port not working
We have a 6509 running 5.4(2). We have set up a hyperterm session and connect to multiple devices, then we get to the 6509 and it will not work. When we reload the 6509 and we are consoled into it, we get data until it is finished reloading. Then the console connections is no longer there. Any help will be appreciated.
Bronze
Re: 6509 Console port not working
Do you have two supervisor in the chassis
Erum
No we only have 1 supervisor in the chassis. It also has the MSFC on that sup.
Is the 6509 config default for the console port!!
Secondly - not this issue related - I would upgrade to a later IOS.
Erfrahim,
I have two supervisor in the chassis and the same problem. Console not work after format bootflash, reload IOS cat6000-sup2k8.7-6-7.bin and reeset in rommon mode. Pls help me
Hong Linh
Email: linh727@yahoo.com
Are you using aaa to control console access?
Can you upload the aaa configuration & config of the console port?
768
