Webcast-Catalyst9k
6509 layer 3 interface
I tried to create a "Layer 3 Interface" on my 6509 and connect that to a "Layer 3 interface" on another 6509. The link is up/up and I can see the other side using cdp, but I cannot ping the other side. During a debug of the ping I see the error "encapsulation failed".
I found in the documentation that "Catalyst 6500 series switches support Layer 3 trunks only on the 4-port Gigabit Ethernet WAN module (OSM-4GE-WAN)".
I am confused about the Layer 3 trunk?
Is a Layer 3 interface the same as a Layer 3 trunk? If so then I guess I cannot do this on a supervisor or 16 port GIG blade.
Does this mean I cannot have the following config connect the two GBICs with fiber and ping across?
6509 #1
Router(config)# interface gi3/1
Router(config-if)# ip address 192.168.1.1 255.255.255.0
Router(config-if)# no shutdown
6509 #2
I have tried different fiber, GBIC's, and a 4006 but I still cannot get pings to flow across.
Thanks for you help
Re: 6509 layer 3 interface
You should be able to connect the 2 switches using routed ports like the way you have configured. Layer 3 trunk is a different concept and you are not using it. Do you have the ip address 192.168.1.1 on both switches? Paste the output of sh int gig 3/1 from both switches and also what software version are you running? What kind of modules are you using in slot3?
Sorry, my mistake. I do not have 192.168.1.1 on both interfaces. I have 192.168.1.1 and 192.168.1.2.
The module is a WS-X6516-GBIC.
GigabitEthernet3/1 is up, line protocol is up
Hardware is C6k 1000Mb 802.3, address is 000a.42d7.14ca (bia 000a.42d7.14ca)
Internet address is 192.168.1.1/24
MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
Keepalive set (10 sec)
Full-duplex mode, link type is force-up, media type is SX
output flow-control is unsupported, input flow-control is unsupported, 1000Mb/
s
input flow-control is off, output flow-control is off
Last input 00:00:05, output 00:00:15, output hang never
Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 85
Queueing strategy: fifo
Output queue :0/40 (size/max)
L2 Switched: ucast: 12 pkt, 4528 bytes - mcast: 22 pkt, 3592 bytes
L3 in Switched: ucast: 0 pkt, 0 bytes - mcast: 0 pkt, 0 bytes mcast
L3 out Switched: ucast: 0 pkt, 0 bytes
150 packets input, 20821 bytes, 0 no buffer
Received 39 broadcasts, 0 runts, 0 giants, 0 throttles
154 packets output, 13918 bytes, 0 underruns
0 output errors, 0 collisions, 5 interface resets
0 lost carrier, 0 no carrier
More information. If I create a VLAN, assign the IP address to the VLAN and then make port gi3/1 a member of that VLAN it works.
137
