6509 Module problem, question!!!
Hi, I had the following problem last night, I would like to know if anyone have expirienced the same:
One module on my catalyts 6509 for any reason took a power down state, at the same time my active supervisor becanme in standby when I did a switch supervisor command the module became in power down state.
Now, when I use the standby supervisor as the active, everithing work properly.
Version 5.5(1)
Can somenone help me with that?
Lp
1 REPLY
Silver
Re: 6509 Module problem, question!!!
You can try reseating the module which shows power down .Mostly, this itself will resolve the issue. If the problem still persists, if you use any other switch, try the same module in any other switch. Even then, the problem appears,just send me what module it is?. I mean whether it is a GB ethernet module or a voice module etc?. I want to know this information so that based on the module that has shut down, I can provide an apt solution to the problem.
152
