6509 not forwarding or seeing multicast.
My problem is that the 6509 is not propogating/forwarding a new multicast stream. The only thing I?ve noticed is that the 6509 is not recognizing this new multicast from two different new servers running VLC (we've tried linux and windows). If I have a client do an IGMP join on the same vlan it works, I can see the stream. In my configuration I need the 6509 to detect the multicast and stream it regardless of any IGMP join requests. This works for ALL other channels except with our attempts to add our own channel using a linux/windows solution. The 6509 does not recognize the source:
PhatCat#sho ip mroute count | i 239.70.3.0
Group: 239.70.3.0, Source count: 0, Packets forwarded: 0, Packets received: 0
PhatCat#sho ip mroute count | i 235.1.1.1
Group: 235.1.1.1, Source count: 1, Packets forwarded: 10118880, Packets received: 10142654
#sho ip mroute summary
!Example of stream not recognized and not working:
(*, 239.70.3.0), 7w0d/00:02:33, RP 0.0.0.0, OIF count: 2, flags: DC
!Example of working stream on same vlan!
(*, 235.1.1.1), 7w0d/stopped, RP 0.0.0.0, OIF count: 2, flags: DC
(10.100.41.10, 235.1.1.1), 7w0d/00:02:52, OIF count: 1, flags: T
#sho ip igmp groups
IGMP Connected Group Membership
Group Address Interface Uptime Expires Last Reporter
239.70.3.0 Vlan941 01:59:49 00:02:29 10.100.41.135
235.1.1.1 Vlan941 7w0d 00:02:27 10.100.41.10
I have over 150 multicast channels streaming from our video head-end with 7 different encoders. I also have a unix server that is sending out another 15 multicasts (10.100.41.10). We?ve sniffed (captured with ethereal) the traffic and we don?t see anything different from other multicasts that work. I?ve gone through this document and haven?t found anything different between the working and failing multicasts. HELP!
Re: 6509 not forwarding or seeing multicast.
tough one, since this problem appears to occur only with one particular multicast group. Can you do a:
debug ip pim
debug ip igmp
debug ip mrouting
and post the results ?
Also, which IOS version are you running ? There is always a chance that this is a bug...
GNT
Repeated Several times:
51w6d: IGMP(0): Received v2 Report on Vlan941 from 10.100.41.135 for 239.70.3.0
51w6d: IGMP(0): Received Group record for group 239.70.3.0, mode 2 from 10.100.41.135 for 0 sources
51w6d: IGMP(0): Updating EXCLUDE group timer for 239.70.3.0
51w6d: IGMP(0): MRT Add/Update Vlan941 for (*,239.70.3.0) by 0
51w6d: MRT(0): Update (*,239.70.3.0), RPF /0.0.0.0
51w6d: MRT(0): Update Vlan941/239.70.3.0 in the olist of (*, 239.70.3.0), Forward state - MAC built
51w6d: IGMP(0): Received v2 Report on Vlan941 from 10.100.41.10 for 235.1.1.1
51w6d: IGMP(0): Received Group record for group 235.1.1.1, mode 2 from 10.100.41.10 for 0 sources
51w6d: IGMP(0): Updating EXCLUDE group timer for 235.1.1.1
51w6d: IGMP(0): MRT Add/Update Vlan941 for (*,235.1.1.1) by 0
51w6d: MRT(0): Update (*,235.1.1.1), RPF /0.0.0.0
51w6d: MRT(0): Update Vlan941/235.1.1.1 in the olist of (*, 235.1.1.1), Forward state - MAC built
Version 12.2(18)SXD4, RELEASE SOFTWARE (fc1)
Thanks for your help!
349
