Webcast-Catalyst9k
6509 upgrade issues
Replacing my network at the moment.... in the Core DC I have 2 x 6509's which were running 1300W PSU's and single Sup2-MSFC's......
Just replaced the fan tray and PSU's to now be 4000W and installed a Sup720 running Native.... works great... installed a 24port X6724-SFP module in slot 1 for the backbone fibre and this also works great with no problems...
Now the fun bit... I planned to replace my W6248-48 port RJ45 blades with the newer X6148A-GE-45AF to get gig and PoE.... however these show up as 'unknown' on the sh mod and ' unsupported module' in Ciscoview????
These blased work great in all the new 6509's and 6506's that I have implemented across the site but not in the ones that I have just upgraded....
What is the difference between the old WS-6509 and the new WS-6509-E chassis...??.. and why don't these cards work??.. I put the old ones in and they are fine for now...
Re: 6509 upgrade issues
Are you running at least 12.2(18)SXF? That's the minimum IOS required to support the WS-X6148A-GE-45AF
HTH,
Bobby
My Sup720 is loaded and running 12.2(18)SXD5.. I guess that is my problem then.....
An upgrade already........ no surely not?!?!
Unfortunately, that is the case.
This is documented in the Release notes:
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat6000/122sx/ol_4164.htm#wp2560852
You can always use this document to ensure that you get the IOS that supports all of your hardware.
Hope that helped!
-Bobby
Interesting however that the IOS selection tool gives different versions to this document when I let it choose from my hardware lin-up...
.. ho hum.. shal upgrade and see what happens
174
