6513 Sup720-3b ROMmon problem
hi folks,
got an issue here at a remote site. the engineer was converting from catos to ios, following the listed procedure at http://www.cisco.com/en/US/products/hw/switches/ps708/products_tech_note09186a008015bfa6.shtml. After Step#12 [formatting bootflash], he noticed all the linecards' LEDs were amber. he rebooted the switch, fearing a power/temperature issue & promptly landed the switch at ROMmon. no CF card so he started with xmodem recovery. tried xmodem -ys38400 & xmodem -c. he got separate errors in hyperterminal [windows xp]:
1. error limit exceeded
2. no response from remote system
retried xmodem, with various flowcontrol settings, to no avail. tried using a different console cable/laptop; same results each time. searching around brought up a config-register change to 0x3921, which purportedly changes the console speed to 115.2k, in an effort at getting xmodem to work [remember, no CF card].
now, hypertrm shows nothing but garbage. reconnecting at all speeds 120-115200 and
issuing different Breaks "CRTL+Break" "Break" "hold space bar for 10
seconds on boot" "Shift 6 + Shift 4 + Shift b" produces nothing so basically ROMmon is gone too.
let me summarize. no CF card. ROMmon seemingly gone. and xmodem unhelpful.
any idea on how to recover from this? he does have a redundant sup720-3b running catos but if he inserts both in the 6513, he gets nothing but 'unknown' for module 7 [1st sup] & he can't access its slave-bootflash or slave-supbootflash, or any such.
any ideas? any suggestions? i've asked him to try using another terminal emulator, procomm or teraterm, just to eliminate hyperterminal but the ROMmon seems to be inaccesible at this point. i'd *really* appreciate any help folks...
  • Other Network Infrastructure Subjects
1 REPLY
Re: 6513 Sup720-3b ROMmon problem
turns out that he had to use procomm [not hyperterminal] at 400bps to get console access...FYI...
514
