Webcast-Catalyst9k
6513 switch features
I have a 6513 switch. One of the nice features is that once a pc or device is unplugged from the network it desplayes a message on the console with port showing the unit left network. The same with once a unit is connected. Is this a feature that is turned on or off ? I have a 6509 that dose not display the information.How can I turn it on for the 6509?
1 REPLY
Re: 6513 switch features
Are you running IOS or CAT OS? If running IOS, you need to enable "logging event link-status" under interfaces. If running CAT OS 7.x and 8.x, enable logging using "set logging level ethc 5 default" and if running CAT OS 5.x or 6.x, the command is "set logging level pagp 5 default".
94
