7140 console port problem
I had an instance where I could not access the console port on my 7140 router. A reboot fixed the problem. Could this occur when the sys utilization is to high, or does anyone have any other ideas?
1 REPLY
Re: 7140 console port problem
I can't say what the cause is but might be able to save you a reboot if it happens again. In the past when this has happened to me, I telnet into the router and issue 'clear line cons 0.' This usually does the trick.
102
