Community Member
7200 series router problem
hi everbody
i am facing a problem please help me. i have a 7200 series router whenever i try
copy run start
it shows me
Startup-config file open failed(No device available)
Plz tell me the possible reasons
1 REPLY
Re: 7200 series router problem
The reason could be a corrupted/failed NVRAM, which you would have to replace then.
In the meantime you should store the config on a TFTP server or in the flash (do not erase it!!!), which the router could use during startup.
Regards, Martin
139
