Bronze
7204VXR and PA-MC-8TE1+
Hi all, I've been trying to get a 7200 to recognise the above PA.
I've tried several Kboot images (12.1(8a)E, 12.2(2)T and 12.2(8)T5) various IOS's from 12.1(14)E to 12.2(8)T, T1-5 with no luck.
I/O controller is a 2FE/E and processor is a NPE400
PA has been RMA'd to no effect.
Any ideas?
1 ACCEPTED SOLUTION
Re: 7204VXR and PA-MC-8TE1+
To continue your PA-MC-8TE1+ port adapter installation, you must configure the card type as either T1 or E1.
The controllers will not be visible till the card type is configured on the PA. After configuring card type as T1/E1 on the PA, all the controllers are created as T1/E1.
The CLI to configure card type for PA-MC-8TE1+ port adaptor as T1/E1:
On 7200,7400 Platform:
Router#
Router(config)#card type
For additional information please refer to these links:
http://www.cisco.com/en/US/products/hw/modules/ps2033/products_module_installation_guide_chapter09186a008007cfbc.html#xtocid0
Router#
Bronze
Thanks, I'll try that and let you know how I got on.
Cheers
Bronze
That did the trick!
Many thanks.
Ross
98
