7206 Configuration Help
I recently bought a 7206 Router on ebay. I don't have the passwords to get into the router. How do I remove the configuration from the router and start from scratch?
Re: 7206 Configuration Help
Start here:
http://www.cisco.com/warp/public/474/pswdrec_7200.shtml
After you get into privlidged mode:
config t
erase startup-config
control z
reload
The command "erase startup-config" is available in privilaged mode and not in configuration mode
1#erase ?
/all Erase all files(in NVRAM)
nvram: Filesystem to be erased
pram: Filesystem to be erased
startup-config Erase contents of configuration memory
-Bala
94
