7206 CPU load and 'sh proc cpu' output
I have 7206VXR equipped with NPE-300 processing module. It serves several BGP sessions and performs CBWFQ traffic shaping on outgoing FE interface simultaneously. CPU load in my implementation increases constantly and matches complexity of the policy that is used for outgoing traffic (number of classes and ACLs defined) and total bandwidth flowing through the router. Thus all is going according to my estimations. But does anybody know why I can't see IOS process(es) utilizing CPU resources?
This is sample 'sh proc cpu' output:
Cisco_7206#sh proc cpu | excl 0.00%
CPU utilization for five seconds: 39%/38%; one minute: 43%; five minutes: 43%
PID Runtime(ms) Invoked uSecs 5Sec 1Min 5Min TTY Process
21 14256924 3241838 4397 0.24% 0.10% 0.10% 0 Net Background
38 226229296 854805417 264 1.31% 1.13% 1.17% 0 IP Input
Question is - where are 40% of the load hiding?
At this moment policed traffic was about 20 Mbits.
P.S. I'm using IOS 12.2.6, flow switching, TurboACLs etc.
  • Other Network Infrastructure Subjects
Silver
Re: 7206 CPU load and 'sh proc cpu' output
Looks like most all of your processing is being done via Interupt level processing (38% of it).
Here is a link that within explains some reasons for interupt level processing. Most commonly this can be caused by fast switching.
http://www.cisco.com/warp/customer/63/highcpu.html#2
See : High CPU Utilization due to Interrupts portion.
Hope this helps,
Don
Thanks for link, but I've read this document many times already trying to determine dependencies between my config and existing CPU load.
You mean that if I'm using fast switching, it can create this load?
Actually 3 types of switching are configured on the router - Fast Switching, CEF and flow switching. I see also that there are throttles on FE interface that is receiving all traffic coming to the router.
Cisco_7206#sh int fast 0/0 switching
FastEthernet0/0
Throttle count 13
Drops RP 13 SP 0
SPD Flushes Fast 77 SSE 0
SPD Aggress Fast 0
SPD Priority Inputs 0 Drops 0
Protocol Path Pkts In Chars In Pkts Out Chars Out
Other Process 543 607965 1190195 71411700
Cache misses 0
Fast 0 0 0 0
Auton/SSE 0 0 0 0
IP Process 543718302 2493051456 52562327 1210881018
Cache misses 1708
Fast 843181915 1287320062 1507704860 1594094104
Auton/SSE 0 0 0 0
DEC MOP Process 0 0 19811 1525447
Cache misses 0
Fast 0 0 0 0
Auton/SSE 0 0 0 0
And here is switching configuration on the same FastEthernet:
Cisco_7206#sh ip interface fast 0/0
FastEthernet0/0 is up, line protocol is up
Internet address is 194.52.0.98/30
Broadcast address is 255.255.255.255
Address determined by setup command
MTU is 1500 bytes
Helper address is not set
Directed broadcast forwarding is disabled
Outgoing access list is not set
Inbound access list is not set
Proxy ARP is enabled
Security level is default
Split horizon is enabled
ICMP redirects are always sent
ICMP unreachables are always sent
ICMP mask replies are never sent
IP fast switching is enabled
IP fast switching on the same interface is disabled
IP Flow switching is enabled
IP CEF switching is enabled
IP Flow switching turbo vector
IP Flow CEF switching turbo vector
IP multicast fast switching is enabled
IP multicast distributed fast switching is disabled
IP route-cache flags are Fast, Flow, CEF
Router Discovery is disabled
IP output packet accounting is disabled
IP access violation accounting is disabled
TCP/IP header compression is disabled
RTP/IP header compression is disabled
Probe proxy name replies are disabled
Policy routing is enabled, using route map kedr-by
Network address translation is disabled
WCCP Redirect outbound is disabled
WCCP Redirect inbound is disabled
WCCP Redirect exclude is disabled
BGP Policy Mapping is disabled
IP multicast multilayer switching is disabled
But incoming traffic never exceeds 30 megabits. Do you think it is already close to to maximum processing power of NPE-300? I had an idea that about 45 Mbit is possible to process on 7206VXR with NPE-300.
150
