Webcast-Catalyst9k
7206: data transfer stops over interface
Greetings!
Have met with a problem pas two days.
At a random period of time, traffic halts between gi0/3 interface of 7206 Router and gi0/1 interface of Catalyst 2950TTL connected directly by 5e cable 1m long.
There is no warnings in the logs on both devices. No errors on interfaces or other things, usually caused by physical problems (cable,speed/duplex mistmatch etc.)
We loosing connection to Catalyst. ping to it's address stops and no traffic is going through the interface.
The _only_ one way (except performing 7206 to do reload) to resolve a problem is logging on to 7206 and do
conf t
int gi0/3
shutdown
no shutdown
This is our current configuration of interfaces:
7206:
interface GigabitEthernet0/3
description Internal Network (802.1Q)
no ip address
ip route-cache flow
no ip mroute-cache
duplex auto
speed auto
media-type rj45
no negotiation auto
no cdp enable
end
Catalyst2950:
interface GigabitEthernet0/1
description Link to 7206
switchport mode trunk
end
Network is not overloaded (about 5-6k pps, about 30-40 Mbit/sec over interface).
We've used this configuration over past year without any problems.
Have any idea ?
Re: 7206: data transfer stops over interface
The issue could be the vlan interface addresses on the switch and on the router, which should be the default gateway for the switch. Can you post those config too?
On the switch, G0/1 is a trunk port but you don't have the vlans allowed through that trunk. By default only vlan 1 goes through the trunk in this case.
Gary
I'm afraid this is not a vlan issue
here is a part of config (ip's modified)
7206:
interface GigabitEthernet0/3.1
description Network Hardware (VLAN 1)
encapsulation dot1Q 1 native
ip address 1.2.3.193 255.255.255.192
ip access-group Telnet out
no ip redirects
no ip proxy-arp
no ip mroute-cache
arp timeout 600
no cdp enable
end
and 2950:
interface Vlan1
ip address 1.2.3.201 255.255.255.192
no ip route-cache
ip default-gateway 1.2.3.193
I'm not sure about "by default only vlan 1 goes through the trunk..". As far, as I can see, all vlans from 7206 (i.e. gi0/3.xxx) are going through this trunk as I can see at 2950. We are using VTP transparent. The whole schema is working for a long period of time.
I'm writting this from that switch. At this moment I have 34mbps in and 24 mbps out. Last time problem has been occured 7 hours ago. shutdown/no shutdown at 7206 gi0/3 is only one thing that we've made to return connectivity.
I'll probably will do an interfaces change (won't do this btw because we have a number of vlans, that should be renamed in this case) to eliminate hardware problem, but it seems to me, that here are some logical problems, maybe in IOS. But it's hard for me to belive, that in "basic" operation -- switching Cisco make an error.
Anyway. Have no idea yet. While writting this message I have changed the cable between two devices. And after 3 minutes, the problem occured again.
219
