09-26-2003 01:05 PM - edited 03-02-2019 10:37 AM
I am interested on using point-to-point connections between 6 T's using a 7206 non VXR router that I am willing to purchase used, has a PA-8E card and a PA-T3-DS3, I am not sure if I can achieve this concept with this chassis, the specs on the router are below, any thoughts would be appreciated.
IOS (tm) 7200 Software (C7200-K4P-M), Version 12.0(21)S1, EARLY DEPLOYMENT RELEA
SE SOFTWARE (fc1)
TAC Support: http://www.cisco.com/tac
Copyright (c) 1986-2002 by cisco Systems, Inc.
Compiled Tue 19-Feb-02 14:29 by nmasa
Image text-base: 0x60008960, data-base: 0x60FBE000
ROM: System Bootstrap, Version 11.1(13)CA, EARLY DEPLOYMENT RELEASE SOFTWARE (fc
1)
BOOTLDR: 7200 Software (C7200-BOOT-M), Version 12.0(14)S, EARLY DEPLOYMENT RELEA
SE SOFTWARE (fc1)
Router uptime is 0 minutes
System image file is "slot0:c7200-k4p-mz.120-21.S1"
cisco 7206 (NPE200) processor with 114688K/16384K bytes of memory.
R5000 CPU at 200Mhz, Implementation 35, Rev 2.1, 512KB L2 Cache
6 slot midplane, Version 1.3
Last reset from power-on
X.25 software, Version 3.0.0.
12 Ethernet/IEEE 802.3 interface(s)
3 FastEthernet/IEEE 802.3 interface(s)
2 Serial network interface(s)
125K bytes of non-volatile configuration memory.
4096K bytes of packet SRAM memory.
20480K bytes of Flash PCMCIA card at slot 0 (Sector size 128K).
4096K bytes of Flash internal SIMM (Sector size 256K).
Configuration register is 0x2142
Router#
Current configuration : 1655 bytes
version 12.0
service timestamps debug uptime
service timestamps log uptime
hostname Router
ip subnet-zero
ip ssh time-out 120
ip ssh authentication-retries 3
interface FastEthernet0/0
no ip address
no ip directed-broadcast
shutdown
interface FastEthernet1/0
no ip address
shutdown
interface Serial2/0
no ip address
shutdown
dsu bandwidth 44210
framing c-bit
cablelength 10
interface Serial2/1
no ip address
shutdown
dsu bandwidth 44210
framing c-bit
cablelength 10
interface FastEthernet3/0
no ip address
shutdown
interface Ethernet5/0
no ip address
shutdown
interface Ethernet5/1
no ip address
shutdown
interface Ethernet5/2
no ip address
shutdown
interface Ethernet5/3
no ip address
shutdown
interface Ethernet5/4
no ip address
shutdown
interface Ethernet5/5
no ip address
shutdown
interface Ethernet5/6
no ip address
shutdown
interface Ethernet5/7
no ip address
shutdown
interface Ethernet6/0
no ip address
shutdown
interface Ethernet6/1
no ip address
shutdown
interface Ethernet6/2
no ip address
shutdown
interface Ethernet6/3
no ip address
shutdown
ip classless
line con 0
line aux 0
line vty 0 4
end
Router#
Thx
09-29-2003 12:35 AM
I don't understand the question. What do you mean with "6 T's" ? Do you want to connect 6 sites with each a T1 to a central site? In that case you need a PA-MC-T3 which can handle a channelized T3.
BTW, looking at the config, it seems that the router has following interfaces:
2x PA-1FE
1x PA-2T3 (or PA-2T3+)
1x PA-8E
1x PA-4E
hth
Herbert
