7301 max vlans and pppoe sessions supported
Hi all,
Does anyone know the max vlans,pppoe sessions and l2tp tunnels supported on the 7301 router?
Thanks in advance.
Re: 7301 max vlans and pppoe sessions supported
Do find the details which i could obtain from the fact sheets available,if you need more inline with the performance i would suggest to check the brouchers,whitepapers of 7300.
"Best-of-breed broadband aggregation for up to 8000 PPP, RBE, or L2TP sessions"
http://cisco.com/application/pdf/en/us/guest/products/ps352/c1031/ccmigration_09186a0080088a03.pdf
http://cisco.com/en/US/products/hw/routers/ps352/prod_literature.html
http://cisco.com/en/US/products/hw/routers/ps352/products_data_sheet09186a008014611a.html
regds
Not sure if it doesnt support vlan as its a pure router. As far as PPOE session goes, it supports 16K user sessions.
http://www.cisco.com/en/US/products/hw/routers/ps341/prod_brochure09186a0080088763.html
For L2TP or VPN services, you should have VPN module installed.
http://www.cisco.com/en/US/products/hw/routers/ps341/products_data_sheet0900aecd8020b758.html
HTH,
-amit singh
315
