hi,
i have an cisco 7513 running an enterprise ios (123-1a).
the router has a rsp4 and two vip2-50 modules . the first vip-module contains two fasteth portadapters
and the other vip module contains an 8-port serial port adapter and an 8-port e1-isdn port adapter.
on the serial pa there are 5 serial lines (frame-relay and hdlc) connected and on the e1-pa there are two
lines which are bundled via ppp multilink.
the problem is that the router cannot transfer packets greater than 200bytes out of the fast ethernet interfaces when the e1-lines are connected. its no lan-problem because when the e1-lines are removed everthing works fine.
the e1-port adapter and the vip-modules have been replaced, so the hardware seems to be ok.
any ideas ?
thx
hannes
