08-02-2002 09:56 PM - edited 03-02-2019 12:25 AM
hi,
can any body tell me ,what is the modem type of NM-8AM modem module.
i mean wt should i put in the following command as the modem type.
modem autoconfigure type............
should we use CISCO v110 or wt?
regards
sameer
08-03-2002 07:04 AM
Ideally we do not need a modemcap for the NM-AMs so should not have that command in.
The default modemcap microcom_mimic should be fine.
Thanks, Makarand.
08-03-2002 08:04 AM
Internal Analog modems do not need any modemcap..Default is fine unless you want to tweak the modem settings according to application layer requirement..Tejal
08-03-2002 09:37 PM
hi,
i dont want to do do any thing with the MODEMCAP instead i just want to know
what should i put in the line configuration mode as a modem type.
according to my knowledge there are two related commands
1)Modem autoconfigure discovery
2)Modem autocinfigure type discovery
but for the discovery router initialise the modems though it works but i need to
know the exact modem type so that if u i have any doubt about any thing then
i'll be sure that there i s nothing wrong with my modem configurations
on my router the when i issue the SHOW MODEMCAP it shows me the following modems names.
codex_3260
usr_courier
usr_sportster
hayes_optima
global_village
viva
telebit_t3000
microcom_hdms
microcom_server
nec_v34
nec_v110
nec_piafs
cisco_v110
mica
so please tell me which one shold i choose.
regards
sameer
08-04-2002 09:53 AM
cisco3640#sh modemcap
default
codex_3260
usr_courier
usr_sportster
hayes_optima
global_village
viva
telebit_t3000
microcom_hdms
microcom_server
nec_v34
nec_v110
nec_piafs
cisco_v110
microcom_mimic <====
mica
cisco3640#sh ver | inc c3640
System image file is "flash:c3640-i-mz.121-1.T"
NM-AM default modemcap is microcom_mimic.....just to confirm the same:
1)Execute "sh line x"....will show "modem type is unknown"
2)Under line x add "modem autoconf discovery"...now execute "sh line x"
Will see "Modem type is microcom_mimic"
Thanks, Makarand.
