8 Port RJ45 Primary Card Issue on 7200
I have an 8 port primary Module (RJ45) in 2 7200 routers. Each router has an NPE 225 and is running c7200-is-mz.122-8.T10.bin software. The issue I am having is that I can not open anymore than 4 PRI ports on each router. When I try and configure the 5th port, i get a message about router resources not available.Each router has 128MB of memory in them. Has anybody had issues ith these cards before?
Re: 8 Port RJ45 Primary Card Issue on 7200
Can you paste the exact message you are seeing along with the output of sh ver
Anonymous
N/A
below is the error message and out put of the show ver command
%Insufficient resources to create pri-group - it has been removed
sh ver
IOS (tm) 7200 Software (C7200-IS-M), Version 12.2(8)T10, RELEASE SOFTWARE (fc1)
TAC Support: http://www.cisco.com/tac
Copyright (c) 1986-2003 by cisco Systems, Inc.
Compiled Fri 30-May-03 02:46 by kellythw
Image text-base: 0x60008940, data-base: 0x615EA000
ROM: System Bootstrap, Version 12.0(19991120:010612) [nlaw-conn_4xe_ECC 112], DEVELOPMENT SOFTWARE
ITC_ISDN_HUB uptime is 2 hours, 15 minutes
System returned to ROM by reload at 14:06:57 bst Tue Aug 19 2003
System restarted at 14:10:29 bst Tue Aug 19 2003
System image file is "disk0:c7200-is-mz.122-8.T10.bin"
cisco 7206VXR (NPE225) processor (revision A) with 114688K/16384K bytes of memory.
Processor board ID 20401674
R527x CPU at 262Mhz, Implementation 40, Rev 10.0, 2048KB L2 Cache
6 slot VXR midplane, Version 2.0
Last reset from power-on
Channelized E1, Version 1.0.
Bridging software.
X.25 software, Version 3.0.0.
Primary Rate ISDN software, Version 1.1.
2 FastEthernet/IEEE 802.3 interface(s)
124 Serial network interface(s)
10 Channelized E1/PRI port(s)
125K bytes of non-volatile configuration memory.
46976K bytes of ATA PCMCIA card at slot 0 (Sector size 512 bytes).
4096K bytes of Flash internal SIMM (Sector size 256K).
88
