802.1q between 3524XL and Xylan Omniswitch
I want to configure a 802.1q trunk between a 3524 and a Xylan Omniswitch.
On the cisco, I configured the Trunk ENcapsulation dot1q. It doesn't work. I guess the vlan 1 on the Cisco could be the problem.
Have anyone already done such a configuration?
Thks for your help
JP
Silver
Re: 802.1q between 3524XL and Xylan Omniswitch
JP,
VLAN 1 should not be an issue unless you are running into a Native VLAN issue with your Xylan switch. Without your config it's hard to say what could be the problem. here is an example one for you of a Dot1q trunk.
interface GigabitEthernet6/1
no ip address
speed nonegotiate
switchport
switchport mode trunk.
Hope that helps,
Don
Bronze
Are you having the problem with vlan one or all the vlans..
The problem is with all the vlans. I'd like to have a trunk with vlan 2 & 3. My config for the cisco is here:
interface GigabitEthernet0/1
no autonegociation
switchport trunk native vlan 2
Thanks for your help
JP
Bronze
Please make sure the native vlan is matched due to the reason, we never encapsulate packets on the native vlan.
Try to create some dunnmu vlan is the native vlan to see if that resolve the issue. May be the X switch is also encapsulating on the native VLAN.
Silver
If you need to tag the Native VLAN also, so all VLANs are tagged, you can use the following:
vlan dot1q tag native
This command is discussed in the following URL:
http://www.cisco.com/univercd/cc/td/doc/product/lan/c3550/1219ea1/3550cr/cli3.htm#xtocid8
Possibly the Xlan has no Native (untagged) vlan concept that is your problem???
Hope this helps,
Don
227
