802.1q trunking over ethernet
sdurmaz
I have 2610 series router(has only e0/0) and WS-C3550-48 switch.I need two vlan on ethernet segment and to reach them from wan.is it possible 802.1q trunking(not isl) between router(e0/0) and switch(fa0/48)?
efrahim
Level 4
Level 4
yes
Here is the example.. Also if you want you can make the connection to the 3550 switch as the layer 3 - routed link and then run routing protocol to take care of the routing between the switch and the router -
http://www.cisco.com/warp/customer/473/50.shtml
or configure them as the routed ports
http://www.cisco.com/univercd/cc/td/doc/product/lan/c3550/12112cea/3550scg/swiprout.htm
