802.1Q trunking Problem
--begin ciscomoderator note-- The following post has been edited to remove potentially confidential information. Please refrain from posting confidential information on the site to reduce security risks to your network. -- end ciscomoderator note --
Since i configure Trunking between my Cat 3548 and 2600, i cann´t ping or telnet to my switch IP address more (VLAN1) cann some one help ?
between Router and Switch ping and telnet are ok. but from desktop no ping on the switch, ping on both trunking address is ok but not the native Vlan1.
my config
Router
User Access Verification
Password:
RouterTest>en
Password:
Router#sh run
Building configuration...
Current configuration:
version 12.1
service timestamps debug uptime
service timestamps log uptime
hostname RouterTest
enable secret xxxxxxx!
ip subnet-zero
no ip domain-lookup
ip name-server nnnn.nn.n.129
ip dhcp pool WLAN-ClIENT
import all
network 10.60.119.0 255.255.255.0
dns-server nnnn.nn.n.129
default-Router 10.60.19.254
crypto isakmp policy 1
encr 3des
hash md5
authentication pre-share
group 2
crypto isakmp key xxxxxxx address xxx.xx.xxx.36
crypto isakmp keepalive 10
crypto ipsec security-association lifetime seconds 28800
crypto ipsec transform-set DVAGset esp-3des esp-md5-hmac
crypto map DVAG local-address Ethernet1/0
crypto map DVAG 1 ipsec-isakmp
set peer xxx.xx.xxx.36
set transform-set DVAGset
match address 100
interface FastEthernet0/0
no ip address
ip nat inside
speed 100
full-duplex
interface FastEthernet0/0.1
encapsulation dot1Q 1 native
ip address 10.60.19.254 255.255.255.0
interface FastEthernet0/0.2
encapsulation dot1Q 2
ip address 10.60.119.254 255.255.255.0
interface Ethernet1/0
ip address xxx.xx.xxx.62 255.255.255.224
ip nat outside
crypto map DVAG
ip nat inside source route-map nonat interface Ethernet1/0 overload
ip classless
ip route 0.0.0.0 0.0.0.0 Ethernet1/0
no ip http server
access-list 100 permit ip 10.60.19.0 0.0.0.255 172.24.0.0 0.0.255.255
access-list 100 permit ip 10.60.19.0 0.0.0.255 10.100.0.0 0.0.255.255
access-list 100 permit ip 10.60.19.0 0.0.0.255 10.61.0.0 0.0.255.255
access-list 110 permit esp host xxx.xx.xxx.36 any
access-list 110 permit udp host xxx.xx.xxx.36 eq isakmp any
access-list 110 permit tcp host xxx.xx.xxx.36 any
access-list 110 permit ip 172.24.0.0 0.0.255.255 10.60.19.0 0.0.0.255
access-list 110 permit ip 10.61.0.0 0.0.255.255 10.60.19.0 0.0.0.255
access-list 110 deny ip any any
access-list 120 deny ip 10.60.19.0 0.0.0.255 172.24.0.0 0.0.255.255
access-list 120 deny ip 10.60.19.0 0.0.0.255 10.100.0.0 0.0.255.255
access-list 120 deny ip 10.60.19.0 0.0.0.255 10.61.0.0 0.0.255.255
access-list 120 deny ip 10.60.119.0 0.0.0.255 172.24.0.0 0.0.255.255
access-list 120 deny ip 10.60.119.0 0.0.0.255 10.100.0.0 0.0.255.255
access-list 120 deny ip 10.60.119.0 0.0.0.255 10.61.0.0 0.0.255.255
access-list 120 permit ip 10.60.119.0 0.0.0.255 any
route-map nonat permit 10
match ip address 120
Switch
interface FastEthernet0/1
switchport mode trunk
no ip address
duplex full
speed 100
interface FastEthernet0/2
no ip address
interface FastEthernet0/3
interface FastEthernet0/48
switchport access vlan 2
no ip address
interface GigabitEthernet0/1
no ip address
interface GigabitEthernet0/2
no ip address
interface Vlan1
ip address 10.60.19.250 255.255.255.0
no ip redirects
no ip route-cache
no ip mroute-cache
ip default-gateway 10.60.19.254
ip classless
ip http server
thanks for your help
Bronze
Re: 802.1Q trunking Problem
Just a guess because i can't find doc on the route-map and interface references in the IP NAT INSIDE statement, but it looks like your lost traffic is getting permitted in the route map and forced out e0/0.
Cannot see any ip nat inside command. But try to get rid of this
"access-list 120 permit ip 10.60.119.0 0.0.0.255 any" and be specific. Hope that will work
Agnelo Dcunha
98
