802.1X Problem for CAT-5500 and ACS 3.2
I keep getting error msgs on ACS 3.2: "Bad request from NAS", and "Invalid message authenticator in EAP request"
Here is the config for Cat-5500:
set radius server 10.0.0.4 auth-port 1812 primary
set radius key xxxx
set dot1x system-auth-control enable
set port dot1x 4/1 port-control auto
set port dot1x 4/1 initialize
I then follow the ACS configuration using this link: http://www.cisco.com/en/US/products/hw/switches/ps700/products_tech_note09186a00801d11a4.shtml
Audie Onibala
Bronze
Re: 802.1X Problem for CAT-5500 and ACS 3.2
This problem is usually caused by (1) having a bad key, (2) wrong IP defined in ACS, or (3) wrong protocol defined in the ACS server.
I am using RADIUS IETF. The secret key and IP addresses for the switch and RADIUS (ACS) server have been recheck countless times.
Audie
95
