Community Member
803 router booting problem
I have inadvertantly erased the flash of a 803 router and tried to restore it from TFTP server. Unfortunately I get the error message TFTP failed, timeout expired!. Is there any other option?
1 REPLY
Anonymous
N/A
Re: 803 router booting problem
If you can't get TFTP to work (it should be OK) then as a last resort you can try an XMODEM load over the console.
http://www.cisco.com/univercd/cc/td/doc/product/access/acs_fix/800/800swcfg/upg_ios.htm
96
