Webcast-Catalyst9k
804 ISDN disco's and doesn't redial
I've got a Cisco 804 connecting via ISDN and it seems that after about 2.5hrs, the idle-timeout period, it disconnects and it will not reconnect unless you issue a manual isdn call.
Anyone have any ideas on what I should check? Below is my config, any advice would be greatly appreciated!
Current configuration:
version 12.0
no service pad
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname SD-804-01
enable secret 5 xyz
enable password 7 xyz
pots country US
ip subnet-zero
no ip domain-lookup
isdn switch-type basic-ni
interface Ethernet0
description connected to EthernetLAN
ip address x.x.x.x 255.255.255.240
no ip directed-broadcast
interface BRI0
description connected to Internet
no ip address
encapsulation ppp
dialer rotary-group 1
isdn spid1 11122233330101
isdn spid2 11122233340101
no cdp enable
interface Dialer1
ip unnumbered Ethernet0
encapsulation ppp
no ip split-horizon
dialer in-band
dialer idle-timeout 10000
dialer string 5407258319
dialer hold-queue 5
dialer load-threshold 1 either
dialer-group 1
no cdp enable
ppp authentication chap pap callin
ppp chap hostname username
ppp chap password 7 xyz
ppp pap sent-username username password 7 xyz
ppp multilink
router rip
version 2
passive-interface Dialer1
network 10.0.0.0
no auto-summary
ip classless
ip route 0.0.0.0 0.0.0.0 Dialer1
line con 0
exec-timeout 0 0
password 7 xyz
login
transport input none
stopbits 1
line vty 0 4
password 7 xyz
login
end
1 REPLY
Bronze
Re: 804 ISDN disco's and doesn't redial
Well, you have specified the default route, but where is you specified the interesting traffic dialer list. I have not seen any configuration with "dialer-list 1" which is associated with "dialer-group 1" command. Use this one if your's traffic purely consists of "dialer-list 1 protocol ip permit".
Ashok.
With best regards... Ashok ----------- Pls kindly rate if helpful or answered your question.
88
