Community Member
806 Ethernet interface intermittent
Hello people,
I have an 806 that's going to be used as a vpn endpoint but at the moment I am only trying to get connectivity. My outside interface eth1 keeps changing its stat to down to back up without reason. I have tried to connect ot directly to a PC (with a cross cable), a small hub and a switch to no avail, it keeps doing it.
I am at the latest IOS version 12.2.13T IP/FW/3DES
Anybody has any idea apart from a hardware problem?
Simon Thibaudeau
1 REPLY
Bronze
Re: 806 Ethernet interface intermittent
Sounds like a hardware problem. If you have tried different cables and plugging into different devices, and the interfaces still flaps... I would have the 806 replaced.
81
