806 router and cable modems...
I got the Cisco 806 router yesterday. I have a cable modem (non-Cisco). Having a problem getting an IP on the E1 interface. The config is Internet>cable modem>806>PC. Already went to http://www.cisco.com/warp/public/109/router_behind_cm_19268.shtml#intro , but haven't had any luck yet. When I first got the rouer out of the box, hook up everything and could ping the E0 interface, but can't now. Any suggestions?
John
Re: 806 router and cable modems...
The role of 806 router behind non-cisco cable modem is to obtain ip address dynamically (for its one of the eth port) from isp and perform NAT for the internal ip address on a privet LAN..Not to troubleshoot it, we need to know
that the ip address is obtained for eth port connected to cable modem or not..
"sh ip interface brief" will inform that..
From a PC, are you able to ping the privet ip address of the eth port??
The url that you are refering to, does have verification steps, pl. see what do we got in your case..
Try using the built-in web-based tool, Cisco Router Web Setup to configure your router. It has a feature called Test Connection which will test your connection and fix the problem for you.
Ravikumar
I have tried the Cisco Router Web Setup, but didn't get it working right that way. I loaded a new IOS image on it, configured the outside interface to DHCP and it got an IP. Thanks for reply.
John
I'm having the same problem, what IOS version are you using to get it to work?
I'm using 12.2(4r)XM1. I finally got it working a week ago. Now the outside interface gets an IP address ok. I erased the config and started from scratch. When I got the config how it was supposed to look I turned off the cable modem and router, then plugged the cable modem back in then the router. Works fine now.
John
I have my 806 connected to Comcast below is my configuration. Hope it helps you
Route IOS version - c806-k9osy6-mz.122-11.t.bin
Configuration:
version 12.2
no parser cache
no service pad
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname xxxx
enable secret
username xxxx privilege 15 password 7
ip subnet-zero
ip name-server 68.39.224.5
ip name-server 68.39.224.6
ip dhcp excluded-address 10.10.10.1
ip dhcp excluded-address 68.37.x.x 68.37.x.x
ip dhcp pool client
network 10.10.10.0 255.255.255.0
dns-server 68.39.x.x 68.39.x.x
domain-name comcast.net
default-router 10.10.10.1
lease infinite
ip inspect name myfw cuseeme timeout 3600
ip inspect name myfw ftp timeout 3600
ip inspect name myfw http timeout 3600
ip inspect name myfw rcmd timeout 3600
ip inspect name myfw realaudio timeout 3600
ip inspect name myfw smtp timeout 3600
ip inspect name myfw tftp timeout 30
ip inspect name myfw udp timeout 15
ip inspect name myfw tcp timeout 3600
ip inspect name myfw h323 timeout 3600
partition flash 2 6 2
interface Loopback0
ip address 10.1.1.1 255.255.255.255
interface Ethernet0
ip address 10.10.10.1 255.255.255.0
ip nat inside
no cdp enable
hold-queue 32 in
hold-queue 100 out
interface Ethernet1
mac-address 0002.1764.73b9
ip address dhcp client-id Ethernet1
ip access-group 111 in
ip nat outside
ip inspect myfw out
no keepalive
no cdp enable
ip nat inside source list 102 interface Ethernet1 overload
ip classless
ip http server
ip pim bidir-enable
access-list 102 permit ip 10.10.10.0 0.0.0.255 any
access-list 111 permit icmp any any administratively-prohibited
access-list 111 permit icmp any any packet-too-big
access-list 111 permit icmp any any time-exceeded
access-list 111 permit icmp any any traceroute
access-list 111 permit icmp any any unreachable
access-list 111 permit udp any eq bootps any eq bootpc
access-list 111 permit udp any eq bootps any eq bootps
access-list 111 permit udp any eq domain any
access-list 111 permit udp any any eq isakmp
access-list 111 permit tcp any any eq telnet
access-list 111 permit tcp any any gt 1023 established
access-list 111 permit tcp any any eq 6699
access-list 111 permit udp any any eq 6257
access-list 111 permit tcp any any eq 6346 established
access-list 111 permit ahp any any
access-list 111 permit esp any any
access-list 111 deny icmp any any echo-reply
no cdp run
line con 0
exec-timeout 120 0
password 7
logging synchronous
login
stopbits 1
line vty 0 4
exec-timeout 120 0
password 7
login
length 0
scheduler max-task-time 5000
end
Some ISPs bind the subscriber to the PC MAC address. A DHCP request will get a response only if it is sent from the registered MAC address. This might be to restrict the number of PCs behind the cable modem. Try setting the MAC address of 806's WAN interface to that of your PC. Of course, you should give a new MAC address to your PC.
-Ganesh.
You can also try connecting the PC directly to the cable modem, if it gets an IP address, then release it and then try it with your router...
Juan
Ok, thanks. Yeah, now I can get an IP.
John
112
