Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
827 adsl router problem
I've configured a cisco 827 router for adsl connection.All is fine and I can ping evry address on the internet and do dns resolves.However if I connect a pc to this router and attempt a ping I get one reply from that address and then the rest timeout.I can ping both the internal and external interfaces of the router without problem.If I do a ping to a url it resolves to the ip address but still only gives one reply.HELP!!!
version 12.1
no service single-slot-reload-enable
no service pad
hostname router
logging buffered 4096 debugging
logging rate-limit console 10 except errors
enable secret 5 $1$Z1jZ$UkJ4o7LmOIGvSXrT6kgb.1
enable password cisco
ip subnet-zero
no ip finger
no ip dhcp-client network-discovery
--More-- !
interface Ethernet0
ip address 172.29.100.1 255.255.255.0
ip nat inside
no ip mroute-cache
no cdp enable
interface Virtual-Template1
no ip address
interface ATM0
no ip address
no ip mroute-cache
no atm ilmi-keepalive
pvc 0/38
encapsulation aal5mux ppp dialer
dialer pool-member 1
bundle-enable
dsl operating-mode auto
interface Dialer1
ip address 62.49.7.25 255.255.255.0
--More-- ip nat outside
encapsulation ppp
dialer pool 1
ip classless
ip route 0.0.0.0 0.0.0.0 Dialer1
no ip http server
ip nat inside source list 1 interface Dialer1 overload
access-list 1 permit any
access-list 101 permit ip any any
dialer-list 1 protocol ip permit
line con 0
exec-timeout 0 0
transport input none
stopbits 1
line vty 0 4
password
login
--More-- scheduler max-task-time 5000
end
Re: 827 adsl router problem
config looks fine with one or two command is missing under the "interface dialer 1" like "dialer-gr 1" etc..Here is the place which has a sample config for the same
http://www.cisco.com/warp/public/794/827dhcp_unnum.html
Things should work with what you have here is the way to troubleshoot.
Now..first try to do extended ping to the outside ip address with a source ip address of the 827's inside interface..and see the results..
Also use "no ip route-cache" and "no ip mroute-cache" under dialer and ethernet interface and see if that makes any difference....
I have seen this before (On a 2621 with ISDN).
First thing I would do is modify your access-list 1 to only allow the internal range (Not just any)
Second thing would be to upgrade your IOS.
HTH,
MB
How about using built-in web based tool , CRWS to configure your C827. Its a cool tool with an option to test your configuration and connection.
regards,
Ravikumar Eswaran.
I've had a similar problem with an 827, though I didn't get nearly the consistent ping response from the router....Anyway, I suspect this isn't the case with you, but what I did find out is that several ISP's use RFC 1483 *bridging* instead of routing with their ADSL lines. The SWBell price model, is (at least was, I no longer work in the area) something like this:
$40 a month is the "home" DSL which comes in PPPoE
$80 a month gets you 5 public IP's and RFC 1483 bridging
$180 a month (or something like that) gets you RFC 1483 routing.
After we found that out, all we had to do was ask the customer what they were paying and we knew how to configure the 827. If you are pinging out from the router, you are probably seeing the DSLAM without a problem, but check anyway. After that, call the ISP and make sure you are routing. Hope it helps.
Matthew
118
